Quantcast
panasonic pv500 black + white component picture?
usman24
I recently tested a panasonic pv500 via component leads but the picture turned out black and white! This has has happened with two different screens.
Can any body help before I purchase a phd8 I would like to know whether this is a common problem?
ColdKilla
You sure this isnt the output from the thing u are using - if it is the ES10 DVD recorder then you need to change one of the settings on that when using component - I remember mine being in black and white by default.
Cant remember what the setting was but something did need changing!
CK
