Panasonic Ptl 701e
Discussion in 'Projectors, Screens & Video Processors' started by Nexus6, Oct 17, 2001.
  1. Nexus6
    Nexus6
    I was wondering whether Home Cinema Choice magazine will do a review of this new projector from Panasonic. Apparently it has a very quiet fan 29db or below. I am thinking of buying one and with a budget of around £3k. Any suggestions, I am converting a large garage into a cinema so need something with a fairly bright picture.
  2. Stevieg606
    Stevieg606
    Ive seen the PTL501 its okay but you should really look at the Sanyo PLV30 we distribute both these brands and the PLV30 is really doing things, or if you can stretch your budget the PLV60 or VPLHS1.
    Steve
