New Patreon Tier and Early Access Content available. If you would like to support AVForums, we now have a new Patreon Tier which gives you access to selected news, reviews and articles before they are available to the public. Read more.
HI.I have got this connected to my pc.Using a 8800gtx.What resolution do i set it to in the nvidia control panel.720p hdtv,1080i hdtv,1080p hdtv,720p50 hdtv,1080i50 hdtv,1080p24 hdtv,1080p50 hdtv, thanks..
sorry i said that wrong.in the advanced picture settings there is a part where it says advanced cinema mode or something like that.I can only enable it if i am feeding the projector 1080i.When the res is set to 1280x720 that setting is switched off.I am using a dvi from my pc to a hdmi on the projector.Just not sure what that setting does.
