Panasonic Pta e500 or Infocus X
Discussion in 'Projectors, Screens & Video Processors' started by steevs, Aug 14, 2004.
  1. steevs
    steevs
    Jan 3, 2003
    2,910
    68
    wxm
    +72
    it's me again after some more advice, I posted earlier about the panasonic pj, but after much research on the net, I keep seeing this Infocus X1 popping up.
    I know it is quite a lot cheaper, but I have yet to see a bad review of it on the net.
    Bearing in mind the cost doesnt particulary bother me, I just want the best for my money, which should choose?
    thanks
    steve
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    I would compare Infocus 4805 and AE500 as the price point is closer and more of a comparison.
  3. Kramer
    Kramer
    Personally I'd choose the AE500. Three reasons:
    1. Resolution
    2. Resolution
    3. Resolution
    :D
    Seriously, completely different PJs (LCD/DLP) at different price points. Not really a decision anyone can make bar you. Shouldn't be too difficult to get a demo of both.
    :smoke:
  4. 45six
    45six
    Aug 11, 2004
    70
    9
    London
    Does anyone now the native output resolution of an xbox please ?
    Is it the same for games and movies (dvds) ?
  5. Kramer
    Kramer
    A vanilla flavoured Xbox outputs a Pal signal (720x576).
    A modified Xbox can output both Pal & NTSC but more importantly, 480p/720p (progressive scan) & even 1080i (game dependent).
    :smoke:
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Kramer a vanilla Xbpx will output 480p also, only when using YPbPr connectio tho. cant get 576p tho?????
  7. Paul Williams
    Paul Williams
    Jul 4, 2003
    821
    Plymouth/Devon
    +18
    Personnaly I'd go for the X1 if I needed to save money, the 4805 if I didn't, for three reasons;
    1. DLP
    2. DLP
    3. DLP
    but then again I've decided that I'm LCD intolerant. :D Not sure the resolution is really a problem until the screen size increases beyond 7ft wide, based on what I've seen so far. Even then I'd sacrifice resolution for the better colourscape I've found inherent with DLP products.
    Paul
  8. Kramer
    Kramer
    Comprehensive threads on Xbox component output options, progressive scan etc. in the gaming forums. Try a search for more info.
    LCD vs DLP, really a demo is advised as I said but DLP benefits (& detriments) aside, there's a big difference in resolution between the X1 & AE500 (16x9 mode).
    :smoke:
  9. steevs
    steevs
    Jan 3, 2003
    2,910
    68
    wxm
    +72
    Thanks for the info guys, one other thing which may be a problem is the shape of the room i'm putting it in, the problem being that I can only put the pj aboput 7ft maximum away from the screen, will this be a problem?
    Steve :D
  10. theritz
    theritz
    Aug 17, 2002
    2,455
    Ireland
    +27
    Steevs,
    7ft throw distance for the X1 will give you an image 43" x 26" maximum, for the AE500, it will give you an image 61" x 34", acording to the throw distance calculators on projectorcentral .com (which is not always 100% accurate...)
    IMO a 5 ft wide image might be sufficient if the room is quite small, but I couldn't see the point of a projector showing an image the same size as a plasma..... part of the impact of front projection for me is seeing an image of an appropriate scale to reproduce the "cinema" experience - although I realise that this is not the same for everyone......
    Sean.
