rauer
As it seems that everybody else is heading for 16:9 displays, I'm considering a 4:3 XGA LCD projector Panasonic PT-LC75E.
Some properties of the projector are still unclear after web & forum searches and reading the pdf leaflet.
1) The projector has composite and s-video connectors and 2 D-Sub's. Can the latter ones accept progressive YUV component video with a BNC-VGA cable as I've gathered from postings on AVS that the US version 75U can? If so, does it accept both 480p and 576p?
2) If the above is correct, can I feed the projector anamorphic video and make the projector do the letterboxing?
3) Some postings give me the idea that on the 75U, you cannot tweak the color balance with YUV video feed. Is this a problem and especially is it a problem if I apply a filter lens of some sort?
4) Is it advicable to feed this beast with a standalone DVD player at all or should it only be connected to a HCPC/HTPC?
5) Finally, any other comments and experience would be very welcome!
