Few questions folks
My bulb has always ben run on low lamp, its now done 2541 hours, i understand that Panasonic say 2000 hours is the limit in high and you might double that using low, how many hours have other people got out of their own before needing to replace the lamp?
If I carry on with this bulb until it goes is there any danger of breaking any other components?
The best value bulb i can find is off ebay and comes from Japan (part number ET-LAE900), will cost £140 inc p&p approx, comes with english replacement instructions and a filter, will this be ok for my projector? Obviously this is miles cheaper than getting it from somewhere in the uk which are nearly double the price, so i'm just a touch nervous about it!
Thanks in advance for any help.
