Panasonic PT AE700, Are there different models???
Discussion in 'Projectors, Screens & Video Processors' started by Peter Stiff, Jul 3, 2005.
  1. Peter Stiff
    Peter Stiff
    Jun 9, 2003
    99
    11
    South Benfleet, Essex
    +6
  2. neil c
    neil c
    Mar 25, 2005
    537
    +3
    As far as I know there is only the PT-AE700E. I'd suggest buying it from Discount Electrical (forum sponsors) for £999 inc. vat and delivery.
  3. Peter Stiff
    Peter Stiff
    Jun 9, 2003
    99
    11
    +6
    Hi Neil,
    Its just looking round the web i seem to have seen the models ending in U and i think the letter C as well.
    Thanks for the info though. :smashin:
    Pete
  4. PJTX100
    PJTX100
    Dec 21, 2004
    8,140
    +564
    Presume they are simply country specific variations eg power lead type etc...PJ :)
  5. Peter Stiff
    Peter Stiff
    Jun 9, 2003
    99
    11
    +6
    Hi Pj,
    Yer that figures..
    Didn't want to buy an older model when there was possible new model without bugs :eek:
    Regards,
    Pete
  6. Mark_a
    Mark_a
    May 27, 2005
    3,064
    +612
    I believe there is two variations - one that has a Scart socket, and one that doesn't, as per the US version. Though their's may not have the 'E' on the end, which I believe stands for 'Europe'.
    Regards
    Mark
  7. Peter Stiff
    Peter Stiff
    Jun 9, 2003
    99
    11
    +6
    Hi Mark,
    Thanks for that think ill have to look slightly closer at this then.. Just wondering if some are selling imported ones cheaper without a scart socket if i would make use of socket myself.
    Was going to run it with component connection. Thanks for the info :thumbsup:
    Regards,
    Pete
  8. soundfreak
    soundfreak
    Here in Australia, the model is PT-AE700E
    In the US the model is PT-AE700U.
    Apart from what voltage they run on, I don't believe there are other differences.
  9. Peter Stiff
    Peter Stiff
    Jun 9, 2003
    99
    11
    +6
    Hi soundfreak,
    Do you have a Scart socket on the back of your unit?
    I was more worried though if the letter at the end was for different versions that have been tweaked in some way but am of the opinion that it is to do with voltage and video connections.
    Regards,
    Pete
  10. benji_m
    benji_m
    Apr 14, 2002
    708
    Lancashire
    +6
    The European ones have an E Suffix and include a SCART socket. Now the difficulty comes in which division of Panasonic in Europe bought the PJ (for warranty issues) which can only be ascertained by asking the retailer. Firmware is another issue, all ours are 1.07 but this can only be determined by serial no or actually a trip to the service menu which we invariably make when pixel checking the projectors.
  11. Peter Stiff
    Peter Stiff
    Jun 9, 2003
    99
    11
    +6
    Hi benji_m,
    Further searching the net has proved what you say is correct.
    Just purchased one which was a PT-AE700E which has a scart socket on the back aswell has HDMI in, S-Video in, Composite in, and Component in.
    Regards all, :smashin:
    Pete
