panasonic PT-AE300
Discussion in 'Projectors, Screens & Video Processors' started by kamarjelin, Aug 30, 2004.
  1. kamarjelin
    kamarjelin
    Have just recieved my Panny AE300 but cannot seem to get any component signal from my toshiba SD220E component output, i selected RGB output on the DVD, then selected Y,Pa,Pr on the projector but no signal. When using VIDEO IN or S-VIDEO IN, no problems. Does anyone have any suggestions as to why this might be, i would like to use component output as i hear it's the best connection to use for best picture quality. :lease:
  2. fomoria
    fomoria
    Aug 9, 2003
    17
    3
    Bournemouth
    Hi, I have the same DVD player. To output through the component sockets, the DVD setting has to be at Video or S-video. RGB setting outputs through the scart. This is somewhere in the manual i think?
    It does get recognised by my projector as a component signal, and for me is much better then either the video or S-video signals.
    Kev.
  3. kamarjelin
    kamarjelin
    Cheers Kev, :thumbsup:
    Have just tried those settings and it works a treat. Have lost my tosh manual so i was hoping someone would tell me it was just the setup i had wrong. This forum is THE only place to get your AV issues resolved.
