Panasonic PT-AE200, Powerstrip, Pixel Mapping and all that jazz...
Discussion in 'Projectors, Screens & Video Processors' started by Tom Whitaker, Oct 25, 2003.
  1. Tom Whitaker
    Tom Whitaker
    Oct 10, 2002
    280
    +7
    Been looking around this and other forums and I can't seem to find any settings for the 200 and a PC. I want it for DVD... and Max Payne 2 ;)
    Anyone suggest anything?
  2. theritz
    theritz
    Aug 17, 2002
    2,455
    Ireland
    +27
    Hi and welcome to the forums.
    Try using the AE100 1:1 pixel mach ettings for Powerstrip - the panel size is the same (afaik). A search here for the AE100 settings will tell you all you need to know.
    Sean G.
  3. Tom Whitaker
    Tom Whitaker
    Oct 10, 2002
    280
    +7
    Really?! The 200 is 858x484... isn't the 100 852x480 or something like that?
    (Thanks for the welcome too...)
  4. theritz
    theritz
    Aug 17, 2002
    2,455
    Ireland
    +27
    AE100 panel size is 858x484........ the powerstrip setting is 856x480 - see Hoglet's post on this thread for all you need to know.
    Sean G.
  5. Tom Whitaker
    Tom Whitaker
    Oct 10, 2002
    280
    +7
    Thanks guys and especially to Hoglet... I;m typing this onto my wall now and I wouldn't be without your help!
    But my only problem is that I'm getting the vertical banding on the test pattern. Where are these Dot Clock settings I need to change? On Powerstrip or on the projector?
    My graphics card let me match the exact settings from the post.
  6. Tom Whitaker
    Tom Whitaker
    Oct 10, 2002
    280
    +7
    Hmmm... dropped the Pixel Clock to 30.9 and it's rock solid. Should I be happy with that then? The image seems the same as when it was at 31.5... but the background image works fine...
