Panasonic PT-AE100E service menu
Discussion in 'Projectors, Screens & Video Processors' started by alf, Jul 8, 2002.
  1. alf
    alf
    I have had this projector for a couple of weeks, has run ok for the 20+ hours or so. Knock on wood...
    I wonder how I can access the service menu on this machine?
  2. Kramer
    Kramer
    Use the search facility on the top of the page:eek:
    Try "AE-100 service menu".
  3. alf
    alf
    Didn't find the answer that way, Kramer:
  4. Guest
    I found one reference to the service menu looking through those other threads.
    It seems as though you hold MENU and NORMAL down for five seconds. Can't comment on whether it works 'cos my AE100 has been returned for now... :(
  5. StJonno
    StJonno
    Select 'Options' from the main menu, highlight 'OSD' and hold down the enter key
  6. MrCoopz
    MrCoopz
    Jun 28, 2002
    1,107
    63
    +115
    what can u do in the service menu?
  7. xander
    xander
    Jul 1, 2002
    130
    New Zealand
    Not much unfortunately. You can cycle through the R,G,B panels and show vertical and horizontal test patterns in each color (or white). You can also check the PJ's self test including temperature measurement, etc. You can also change the fan speed settings.
    Some users seem to think that there should be another more powerful service menu... the person who finds that will be famous forever in the HT community...
