Panasonic PT AE100 in East Anglia
Discussion in 'Projectors, Screens & Video Processors' started by General Skanky, Feb 1, 2002.
  1. General Skanky
    General Skanky
    Jul 28, 2000
    4,251
    71
    Colchester
    +44
    At last, I've found a dealer who has one!!!!!!
    All the others I've phoned and seen don't have a clue. As soon as I asked this one, wow, instant, yes we have them. They'll phone me when another comes in for a viewing. They also asked about my viewing conditions, how I'll use it and that they also have the little 'blue' Sony there too. So I'll get a good comparison.For Suffolk, that's really good.
    The dealer I am talking about deserves a bit of recognition-
    System Sound
    91 North Street
    Sudbury
    CO10 6RF
    Phone- 01787 372348
    Fax- 01787 881816
    So I'm on the path to a projector too, hopefully.:)
  2. Anim
    Anim
    Feb 2, 2002
    1,684
    Bollington, Macclesfield
    +62
    I was a few hours from buying the Sony model until this one started getting some good hype.
    I phoned them up to see what advice they would give and must have spoke to somebody different. They didnt have much advice for me (just said they are about the same in quality) which in a way is helpful if I want to save £200 over the Sony model.
    If the image quality is the same on both models then...
    Panasonic PTAE100E
    http://www.panasonic.co.uk/nw/products/product.asp?c=PTAE100E )
    1. Has a connection for a PC built in
    2. Widescreen 16:9
    3. Can be mounted on the ceiling.
    4. Looks ugly
    5. £200 cheaper than the sony.
    Sony VPL-HS1
    http://www.sonyhomecinema.com
    1. Free screen (while stocks last)
    2. Looks stylish (Wife factor)
    3. No 16:9
    4. Table top mounted only
    5. PC connection is an optional extra
    6. Sony imo is a better brand
    Considering the above I would go for the new Panasonic model and spend the extra £200 on a screen unless somebody who has seen both in action can tell me otherwise. I like the idea of ceiling mounting it (see website)
    Krish are phoning me on Monday to see if they can offer it at a better price so will wait and see.
    Anim
  3. Timh
    Timh
    Sep 14, 2000
    5,223
    3
    3
    Altair-4
    +310
    I have the Pt-AE100, I have also seen the HS1 in action, the Panny blows the sony away, the sony also had really bad vertical lines. Check them out for your self, you will see what I am talking about.
    And I will never buy another Sony Product :mad:
  4. Anim
    Anim
    Feb 2, 2002
    1,684
    +62
    Thats the sort of reply that makes me all happy :)
    Panasonic it is, I 99% knew this really, based on the value for money but your post has given me that last 1% needed to buy it.
    Now all I need to find is a motorised screen or my wife won't let me have it...sigh
    Anim
  5. Timh
    Timh
    Sep 14, 2000
    5,223
    3
    3
    Altair-4
    +310
    Anim, check out the other panasonic posts, I have written my first impression's.
  6. Anim
    Anim
    Feb 2, 2002
    1,684
    +62
    Will do.
    Anim
    Just looked at motor based screens for 16:9. costs about £550. eep
  7. Anim
    Anim
    Feb 2, 2002
    1,684
    +62
    Oh, heres a question you be able to help me on.
    The DVD player http://www.techtronics.com/uk/shop/50-pioneer-dv-340-multi-region-dvd-player.html I have supports S-Video out, this is ok but how can I also get the Sky Box to go into the projector at the same time...like some sort of switch box to swap between DVD and sky. I'm not even going to look at the video (its an old cheap one)
    I have a little AV6 Scan Amp for the sound which is fine for the volume limit i have (paper walls and neighbours)
    Anim
