panasonic projectors question
Discussion in 'Projectors, Screens & Video Processors' started by cuewoz, Sep 10, 2003.
  1. cuewoz
    cuewoz
    I am wanting a panasonic projector,
    my question is what is the difference in the 3 on offer 100,200,&300? except price.
    Also what kind of picture size would I get as the media room is quite small.
    The current projector is a sharp cheepy one and I get about a 5' corner to corner size (4:3).
    If the distance to screen is about 7', how big would a 16:9 pic be?
    Thanks in advance
  2. Mr Cheese
    Mr Cheese
    Dec 12, 2002
    411
    Down South
    +19
    From the image calculator at www.projectorcentral.com
    For the AE100
    Distance to Screen: 7.0 ft.
    Calculated 16:9
    Image Size Diagonal Range: 58 - 72 in. ( 4.8 - 6.0 ft.)
    Height Range: 29 - 36 in. ( 2.4 - 2.9 ft.)
    Width Range: 51 - 63 in. ( 4.2 - 5.2 ft.)
    VERY Basically...
    AE100 Basic model, now discontinued
    AE200 Basic model, replacement for AE100, similar spec but has RGB scart in.
    AE300 current top of the range. Higher resolution. Brighter output.
    See here for full comparison.
    There are, however, people with greater knowledge than me on this forum....
