Panasonic product size...
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Supersonic72, Apr 7, 2005.
  1. Supersonic72
    Supersonic72
    Jan 10, 2005
    246
    A bit of an odd question this but hope someone can help...
    Are any of the Panasonic Sky receivers of the same size/width as their range of DVD-R, etc..i.e, the standard 430mm (is that a DIN size?)
    Looking for one of them, current or past models to fit in a stack which
    are all that particular size...
    Thanks!
