Panasonic Problem
Discussion in 'Panasonic TVs Forum' started by madp, Apr 19, 2003.
  1. madp
    madp
    Mar 15, 2003
    302
    London
    +7
    Hi all
    I’m new to the forum in terms of contributing but have gained lots of info from you all.
    I have a problem with my Panasonic 42PWD5. When I feed the on screen display signal from my Yamaha AX2 amp or Yamaha 1300E HD recorder to the plasma via the svhs connection the screen has lines across it and has a slight judder.
    I connect my cable box, into a JS converter, which then goes into the component connections on my av-amp. The DVD player is also connected straight into the second set of component connections on the amp. I also have an xbox, the signal is pushed through my cable box.
    I have tried the usual things such as new cables. Has anyone out there any ideas.
