Panasonic Power Supply Transplant
Craigness
Can the power supply used from this TV (A) into TV (B)?
A
Panasonic PANASONIC TC-P42G10 42" 1080P PLASMA T
B
Panasonic PANASONIC TH-50PZ80U 50" PLASMA
JayCee
Nope.
The TH is considerably older than the TC.
You need a like for like replacement.
JayCee
You need to copy all numbers from the psu pcb then enter them into a Google search.
JayCee
“PCB” is the printed circuit board which the power supply components are mounted on.
Yes, that's the only way to check.
But only if you’re confident (which by the tone of your reply you don't sound TBH) and take full safety precautions.
Similar threads
