panasonic plasmas
Discussion in 'Panasonic TVs Forum' started by nibsen, Oct 4, 2004.
  1. nibsen
    nibsen
    Oct 4, 2004
    5
    Hi,can anyone out there tell me if there are any differences in the quality of the screens between the silver and black framed panasonic plasmas?
    With particullar regard to the thpw6 42 ins.
  2. daveb975
    daveb975
    Oct 25, 2002
    4,360
    103
    London
    +371
    No difference in quality as such, but the black PWD6 has slightly more picture adjustment options, and conforms to the radiation limits for business use.
  3. zedzed
    zedzed
    Jul 12, 2004
    821
    Linlithgow (nr. Edinburgh)
    +13
    Radiation limits for business use are higher than home use I believe - although both should be fine - nothing to worry about unless you sit 2" from the screen!
    Didn't know there were picture adjustment differences bewtween the silver (PW6D) and charcoal (PWD6) versions though. Are you sure? If so - what are they?
    ZZ
