someuser08
Established Member
I was very impressed with all the reviews of TX-P42G10/V10 plasmas that I went to my local JL store to check them in action. They did not unfortunately have V10 (promised to have it on a display within a week though) so I ended up only looking at G10. I have to say that I was rather disappointed to say the least. They looked quite dull comparing to almost everything they had in the shop.
I must admit I never had plasmas before, but I know that comparing them side by side with LCD TVs in bright conditions won't do them any justice, so I was prepared to let that go, however I discovered something else in the process. G10 had incredibly soft picture. After spending quite a bit of time in front of it I went to check out 7th series LED based Samsungs (UE-B7020 in particular) and was really blown away by the difference. Even if don't take brightness/colours into account (even though I did find Samsung colours a bit over the top, it did look quite amazing) there is a world of difference in resolution between them.
Maybe its just because I spend 10+ hours a day in front of high-end 24'' computer monitor (with HD resolution) and I used to watching HD material on it as well, but I find Panasonics plasmas not really comparable to LCDs in terms of details when watching HD material. I know I won't be sitting to the TV that close but not that far either (not more than 7ft) and sharpness difference is very obvious at that distance.
I'm still willing to have a go at watching V10 model in THX mode, but I'm sure that won't bring in any more details. So is plasma not really for me? Should I be looking at LCDs if I want more resolution and actually plan to watch HD material from a PC via HDMI (both Blurays and Freesat)?
