Panasonic plasma
Discussion in 'TVs' started by Neal, Nov 16, 2001.
Tags:
  1. Neal
    Neal
    I have the new panasonic 42" turning up soon. What would anyone suggest I link it to - DVD (progressive scan/multi region)? under £1000.
    -amp? (under£1000)
    - small unobtrusive speaker package (under £1000)
    - cables between each
  2. brattle
    brattle
    Oct 12, 2001
    108
    16
    Bedford
    Am I guessing right that your total budget is £3,000? If so, it would be a shame to waste the prog scan ability of the Plasma.
    I'd go for an Arcam FMJ DVD. £600 more than your £1,000 budget, but if you go for a Denon 3802 (£700) and the Kef Eggs (£650), the difference is made up.
    Alternatively, you could go for the Arcam DV88 with the prog scan upgrade.
