panasonic plasma
Discussion in 'Plasma TVs' started by cliveuk, Jul 31, 2005.
  1. cliveuk
    cliveuk
    Aug 20, 2004
    524
    28
    Folkestone, UK
    +45
    Hi, im looking at getting a Panasonic TH37PV500CAB, where is the cheapest place to get one with a wall mount? ive seen one site selling it for £1950 but they dont say what it comes with.
    thx for any help
  2. bin_man
    bin_man
    Feb 24, 2005
    23
    Do you actually want the 'cab' stand ? If not, you should be looking for the Panasonic TH37PV500WAL. It is also worth knowing whether you really want the 'free' DVD recorder. I got one (TH37PV500WAL) without the DVD recorder (I thought that as it didn't have a freeview tuner it was almost pointless) from 121electricals a couple of weeks ago, it arrived within a couple of days with no problems.
    I haven’t really decided whether it was a good purchase yet, as I am a little undecided about the 'noise' from fan / electric’s and the picture quality. It is generally great, but just watched the 2nd Harry Potter and the bedroom scenes at the start are quite poor. I think people in this forum call the problem 'colour banding' but I don't quite understand all the terminology yet !
  3. pjclark1
    pjclark1
    Jul 19, 2004
    4,411
    Thailand
    +271
    change the settings to "Cinema" mode and the banding should mostly go away.
  4. bin_man
    bin_man
    Feb 24, 2005
    23
    pjclark1, thanks for the tip. To be honest, I thought that I had set it to cinerma mode, but will go back and check... Cheers
