panasonic plasma th-42px20 or th-42phd6uy
Discussion in 'Panasonic TVs Forum' started by ptmonsen99, Nov 3, 2003.
  1. ptmonsen99
    ptmonsen99
    Hello-
    I'm trying to decide between two Panasonic models:
    TH-42PX20U/P or the TH-42PHD6UY
    Any comments on the difference between the two?
    The TH-42PHD6UY seems to be a "commercial" plasma with no speakers, but is significantly cheaper.
    Thanks in advance,
    Peter
  2. gandley
    gandley
    Aug 31, 2003
    5,102
    Paradise Lost
    +269
    The 42phdy is a true hi def panel and has a contrast ratio of 3000.1 and a res of 1024x768.
    the other model has a built in tuner and i think has acurity processing and a contrast ratio of 4000.1 but has a lower res of 852x480. (in uk this is a different model)
    personaly my money would go on the hi definition panel as the other one will down convert anything above 480p to its native res.
    also depends if u want the tuner but if u use digital box/sky why bother.
    hope that helps
  3. steve36
    steve36
    Dec 11, 2002
    965
    Warwickshire
    +33
    I believe the TH-42PX20U is the HD equivalent of the TH-42PA20, ie it includes a tuner and built in sockets.
    The only place I have heard of availability of it is the US, and we will probably never see it in the UK.
    Panasonic consumer UK do not see a requirement to sell either HD version to the uk, probably due to our broadcast standards.
    Steve.
  4. gandley
    gandley
    Aug 31, 2003
    5,102
    Paradise Lost
    +269
    Yeah steve is quite right the all in one is a us only model and i think it has a hdmi input as well. did a google search on it. nice set looks tops.
    dont see why panasonic wont release it here. i expect will see it in uk next year as a new product.....
    we do have a hidef pany but is considered to be a comercial model.
