Panasonic Plasma and Sky Problems Help
Discussion in 'Plasma TVs' started by fecdave, May 24, 2004.
  1. fecdave
    fecdave
    Mar 4, 2004
    137
    16
    I have a Panasonic 42 PA 20 and a Grundig Sky Box. Sound has been perfect until recently when there has been a lot of interference with the sound, a kind of hissing sound
    This only happens with Sky, with DVD there is no interference, i have checked different Scart Leads including High quality ones and the sound is no better
    Any ideas on what the problem could potentially be?
    All help very gratefully received
  2. Elvis
    Elvis
    Have you tried feeding the signal in through a different scart/AV socket on the back of the screen?
    Can you attach your grundig to another TV in the house and see if the problem persists?
  3. fecdave
    fecdave
    Mar 4, 2004
    137
    16
    elvis many thanks for the advice, i have tried different scart sockets and have the same problem
    ill try the sat box on another tv tonight
  4. fecdave
    fecdave
    Mar 4, 2004
    137
    16
    ok hooked the sat box up to another TV and there was the same interference sound, the picture is perfect just not the sound
    ( very relieved the plasma is not at fault)
    is it more lilely to be the sat box that is broken or the F Type connection wire?
  5. Elvis
    Elvis
    Hard to say what the fault might be. If it's under guarantee get it back to the shop you bought it from for repair/replacement. If not you can either tinker with it yourself or resign yourself to the fact that you need a new Sky Box. Maybe now's the time for sky+? :)
