Panasonic Plasma 42" TH-42PV500B sound breakthrough
Discussion in 'Panasonic TVs Forum' started by mandie quest, Mar 11, 2006.
  1. mandie quest
    mandie quest
    Panasonic 42" Plasma TH-42PV500B
    When watching Sky, we can sometimes hear the audio from the dvb/analogue aerial as well, though slightly quieter than the Sky audio signal. ie we hear two audios at once. Has anyone else experienced this or do we have to return the TV as faulty?
    Many Thanks.
  2. bin_man
    bin_man
    Feb 24, 2005
    23
    I used to have the same problem with my 37PV500 when watching DVD's. When it was a problem I selected a 'blank' tv channel and then switch over to DVD and the problem went away. I haven't noticed it for a while but will check it out tonight as I replaced some scart cables and that may have sorted it out.
    Paul
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    it maybe cross talk from the scart cable try upgrading the scart cable an setting the Q-link to monitor nd AV2 using AV1 for Sky (the panel feeds the DVB/analogue tuner out of scart so you can record it on VCR/DVR while watching the other of Sky etc this may be casuing the issue as your feding sky audio "up" the scart and DV audio "down" a poorly made scart will mix them up and potentially cause this problem
