Panasonic Plasma 37" TH-37PWD6UY
Discussion in 'Panasonic TVs Forum' started by lloydde, Nov 10, 2003.
  1. lloydde
    Nov 10, 2003
    I live in the UK and I want the 6th generation Panasonic Plasma 37" TH-37PWD6UY (or PT37PD4P). Problem is they don't sell it in the UK, only a 42" version or a 37" version with speakers attached.
    Does anyone know who could supply me with this model? Have you any advice to give me in respect of compatability? I can buy the PAL Tuner here in the UK but will it fit/work with the US screen? Also there is presumably a power problem - can I get a power converter so that I can use the screen with a UK power supply. My research on the internet indicates that the display's power unit deals with both power supplies and that the display accepts PAL, but I am worried I may not be reading this right.
    Any help you can give would be much appreciated.
    Thank you David Lloyd
