Panasonic Picture/sound problem
anderson64
I have a recently purchased a m/r Panny ES10 that may have a problem, but before I take apart my whole system to check I thought I would query it here.
I have been using it off air with no problem, however I tried to record from my Tivo and all I got was a heavily green tinted picture with no sound, the same when watching the "live" recording via pass through. I have also noticed that when in timer mode the recorder will provide what I think is a pass through picture but again with no sound.
The unit is connected to the Tivo via a Quintro switchbox and to my plasma via scart.
Any ideas/known problems?
JayCee
Outstanding Member
Have you tried another scart lead?
G
greeny
This sounds like you have the connections set wrong in the menus to me. For example if you are sending component output you cannot also send RGB.
Have a play with these settings, it's not that straightforward and took me a while to get the Sky/plazma setting right
Tribit StormBox Blast Bluetooth Speaker: Review Coming Soon
