Panasonic picture position settings with tuner connected
Discussion in 'Panasonic TVs Forum' started by SCARFACE, Jan 13, 2003.
  1. SCARFACE
    SCARFACE
    Hi there
    Is there anyway to change picture position/settings(vertical/horizontal) while the tuner is connected as it appears to be disabled. My 42pw5 plasma is missing some information at the top(i,e. E4 icon slightly off screen).
    If not, I was wondering by disconnecting the tuner board and changing these settings would they stay the same when reconnecting the tuner or would they revert back to the original settings.
    Any help much appreciated.
    Regards
    Gordon
  2. SCARFACE
    SCARFACE
    Hi there
    40 views of my thread and no one can help me, come on guys someone must have an answer .
    Gordon
  3. d_devani
    d_devani
    Have u tried changing the aspect settings, OK u might have already tried this but just a thought
    Press the aspect button on the remote and flick between 16.9,zoom,just mode.
    I find that sometimes on just mode I get the same error as u. Try using 16.9
  4. SCARFACE
    SCARFACE
    Already checked all aspect ratios, but thanks anyway.
    Regards
    Gordon
  5. StooMonster
    StooMonster
    Nov 20, 2002
    4,974
    Kent
    +314
    You can't do this Tuner. It does limit the options available to you.
    StooMonster
  6. Nick23
    Nick23
    Feb 25, 2002
    121
    16
    while we are talking about tuner problems, how do you get the screensaver to work with the tuner connected?
  7. boogie man
    boogie man
    Dec 4, 2001
    233
    19
    Sunny Berkshire !!
    You Can't Sorry Not With tuner connected
    Boogie man
  8. Nick23
    Nick23
    Feb 25, 2002
    121
    16
    So what do i need to remove? Just the cable end that plugs into the screen, or do i need to remove the whole tuner terminal board to get access to the screen saver?
  9. per_strom
    per_strom
    Just remove the cable from the tuner (or the plasma).
    There is no need to remove the card.
    Then you should be able to run the Standard menu and access the screensave menu.
  10. StooMonster
    StooMonster
    Nov 20, 2002
    4,974
    Kent
    +314
    But they only affect the VGA setting, and don't change any tuner settings.
    StooMonster
