Panasonic PH9 Colour Settings
Discussion in 'Panasonic TVs Forum' started by Dr. Robert, Jan 9, 2008.
  1. Dr. Robert
    Dr. Robert
    Jan 4, 2008
    662
    leeds
    +16
    I am not getting the option on my plasma to change colour or tint when using hdmi out of my pc, going through my onkyo 875. through sky hdmi is ok and if i use component out on my pc thats fine as well.
    any ideas?
  2. Chris5
    Chris5
    Mar 21, 2004
    1,299
    63
    Herts., uk
    +182
    Their are no user settings to change the colour of RGB colorspaced HDMI, only component Colorspace.
  3. Dr. Robert
    Dr. Robert
    Jan 4, 2008
    662
    leeds
    +16
    could you just dumb that down a bit please, i'm not sure what you mean.
    how do i go about calibrating it?
    why does sky hd via hdmi allow this?
    cheers
  4. Chris5
    Chris5
    Mar 21, 2004
    1,299
    63
    Herts., uk
    +182
    Sky output HDMI encoded in a component type format that can be adjusted by the plasma, however it sounds as though the onkyo converts the format to RGB before outputing by HDMI. There may be an option on the onkyo to output in component format instead of RGB. if not, your stuck.
  5. McFaber
    McFaber
    Aug 23, 2006
    2,197
    +144
    It could come under something called YUV .....:)
