panasonic pe37 help.
Discussion in 'Panasonic TVs Forum' started by knobbs, Aug 27, 2005.
  1. knobbs
    knobbs
    hi ive got a panny pe37 pic is very good on sky even most of the low bitrate channels. but a bit unhappy when watching footy, slight artefacts around players, especially when the camera zooms far away and the cameras panning across the pitch, also slight motion blurr with the grass.
    ive tried all diff settings dynamic, cinema and normal, you can improve it a bit in cinema or normal mode, but u lose the great colours as with dynamic mode.
    anyone got any settings to try with this panel.
    i had to watch last nights footy on my 21in lg lcd which close up is a bit dodgy, but from about 8-10 feet away is crystal clear no motion blurr or artefacts.
    does this happen on all plasmas.
