Panasonic PE30 on a wall bracket
Discussion in 'Home Cinema Buying & Building' started by Froggins, Aug 10, 2004.
  1. Froggins
    Froggins
    Anybody got a PE30 on a wall bracket, i'm undecided whether to hang it or buy the stand?
  2. Brigadeer
    Brigadeer
    I wall-mounted mine last Tuesday...bit of messing about will bracket spacers and tight on cable space...but well pleased :smashin: .
  3. kocl
    kocl
    Jan 8, 2003
    602
    PORTUGAL
    +14
    how long it takes to wall and the plasma, minus 20 cm.
  4. Si133
    Si133
    I had mine in less than half an hour. It looks great.
  5. sabujo
    sabujo
    I'm going to get this one. There is enough space to plug all the cables in the back, is tiltable and is not that expensive. I already asked the manufacturer about compatibility with the pe30 and the answer was positive.
    http://www.netonnet.de/item.asp?iid=53386
    Anyone from Portugal wanna order too? We'll share the shipping costs :D
  6. fill
    fill
    I put a post up about 2 weeks ago showing my 50" Wallmounted. Included about 5 pics. Do a search and have a look. I really like it. Took about 4 hours in total to wallmount and hide cables.
    thanks
    phil
  7. Froggins
    Froggins
    how did you hide the cables? did you chase into the wall or have special trunking? I'm can't decide what to do?
    Do you have a link to your pictures?
  8. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +142
    http://www.avforums.com/forums/showthread.php?t=143476&highlight=wall
    Search took less than a minute ;) :clap:
    S.
  9. fill
    fill
    cheers Steve!
