Panasonic PE30 Cabinet Stand Tablets
Discussion in 'Home Cinema Buying & Building' started by Alexis Belhomme, Sep 13, 2004.
  1. Alexis Belhomme
    Alexis Belhomme
    Sep 10, 2004
    16
    Hello,
    I'm planning on buying a Panasonic Viera Plasma TV 37PA30 with the cabinet stand.
    Right now I've got a question regarding the 2 tablets underneath the PDP. I wish to know if they are removable and/or if their height can be adjusted. Also, what is the distance between each of them , and their length ?
    Thanks for your time,
    Alexis.
  2. 1_crazy_mofo
    1_crazy_mofo
    Hi i purchased a cabinet on saturday yes the glass is removable but the way it is made you only have a choice of three shelf positions but i have to say the cabinet is worth the £££.
  3. Alexis Belhomme
    Alexis Belhomme
    Sep 10, 2004
    16
    Shelf ! That's the word I was looking for. I'm sorry my english is a bit rusty.
    Given your answer I suppose one can put a shelf in the middle of the cabinet, and eventually not put the other one at all ?! I'll just have to check for the dimensions to make sure my equipment goes there.
    Thanks for your reply.
  4. andypearce
    andypearce
    Jul 14, 2000
    299
    wales
    +8
    It's one of the reasons I was slightly put off the 42" Viera because when I measured the height between shelves I realised my amplifier would not fit without sacrificing a shelf.
  5. Alexis Belhomme
    Alexis Belhomme
    Sep 10, 2004
    16
    If I have to (and I probably will), I'll put the amplifier and DVD on a separate stand. My main problem is the front speaker: it's 23cm tall and weigths a hefty 12kg !!
    However, the viera's cabinet stand is a real eye catcher for me AND it fits the bill concerning my other needs.
