Panasonic PDP435XDE
Discussion in 'Panasonic TVs Forum' started by fugsi, Dec 15, 2004.
  1. fugsi
    fugsi
    Dec 10, 2004
    27
    After intensive research before i go work everyday for the last past 2 to 3 weeks i've made mine up
    I am going purchase PANASONIC PDP435XE
    my budget started from £2,000 to £2,500 then decided push it up to £3,500
    Started of looking from HITACHI 42PD5200 AND 42PD5300 DONT LIKE THE GREY LOOK OF IT
    Look at SONY KDE-MRX1 -- Too Expensive
    Panasonic which i found many people have got but not only from this forum aswell as others .... people just seem to complain about "PANNY"
    So I decided not to go that way !!!!!! Not much of a Risk Taker
    Panasonic which every1 had uproar about is TH42PE30 from John Lewis store... which still have got it on internet for £2,990 with dvd recorder stand + 5 years Guarantee.
    So I came to the conclusion today for some reason as i dont know why i am going for Panasonic PDP435XDE
    As I am not much of a risk taker is this safest bet found 1 store that doing me a deal for
    Pioneer PDP435XDE With Wall Bracket PDPR05XE Tuner PDPS26 black Speakers
    £3,179
    Can You :lease: please let me know if i am going the right way ....
    your opinion will be very grateful to me on making my desision you can also pm me
    thank you :smoke:
  2. Leigh_1973
    Leigh_1973
    Jan 28, 2004
    721
    UK
    +16
    If you can find a Panasonic PDP435XDE i'll eat my hat!
    I think you mean Pioneer ;)
  3. hddvdman
    hddvdman
    Feb 11, 2003
    6,203
    somethere over there but not near here, there
    +156
    go for the pioneer its awesome get the pio 868dvd player for exc pictures
  4. fugsi
    fugsi
    Dec 10, 2004
    27
    do you have a pioneer PDP435XDE ?
    Have you got it wall mounted ?
    have you had any problems with it like buzzing sounds or picture problems
    should i also take out extra warranty or my house insurance will cover me ?
  5. bringiton
    bringiton
    I've seen a demo of the PDP435XDE. I can't really say much about the noise it makes because it was in a shop and it was quite busy at the time. There is only the most subtle difference in picture quality compared to PDP504HDE/PDP434HDE keep in mind it was displaying DVB TV source at the time).
    The biggest benefit on the new range is the colour gradient improvements they've made 7 billion colour gradients. Keep in mind that you'll need a source that has that much detail in it to be able to see the difference.
    All I can say from owning the PDP504HDE is that is a great panel both aesthetically and for picture quality, even up close. I use it attached to 1080i source (XBOX) and 720p (XBOX modded). I also connect my PC to it using a DVI -> HDMI cable I got off Ebay.
    If you want an absolutely brilliant deal try http:\\www.flattelly.co.uk
    Really cheap and excellent price on warranty's. :thumbsup:
    I'm also buying the Panasonic SAXR70 Amp as it's got the HDMI and component in/outs I need. I don't have a huge living room so it's more than enough.
    I really can't recommend Pioneer Plasma's enough. :smashin:
    bringiton
  6. jaguar
    jaguar
    Nov 17, 2004
    186
    It seems that some buzz. Mine does not. I can only hear a buzz when I put my ear very close at the back of the screen.
