Panasonic PD30 Colour Settings
Discussion in 'General TV Discussions Forum' started by 13th Duke, Oct 7, 2004.
Tags:
  1. 13th Duke
    13th Duke
    Hello all,
    Firstly, many thanks to all the contributers about the PD30's issues - they have helped a lot in setting up the TV. However, now I am a bit stuck. I have used the Digital Video Essentials DVD to setup all the aspects of the TV, and am happy with all the settings except the colour. Following the instructions, I can use the "Colour" setting in the Picture menu to achieve a very good blue - but green and red are poor. Red isn't too bad, but green is terrible - I can even see blue through the supplied green filter. When viewing normal TV through my Sky+ box, reds are very heavy - the BBC News logo is scary and anyone in a bright red top or wearing bright red lipstick requires a pair of sunglasses.
    I was hoping there may be someone out there who can help me with the colour settings in the service menu. Using the DVE Colour card and filter I can't seem to affect any change on the poor green and red performance. Anyone got any ideas. I don't understand what the "high" and the "low" signify - and why there is no green high value and why I can't set one. Current settings are:
    COL. RED GREEN BLUE
    HIGH 0139 ---- 0125
    LOW 0438 0512 0408
    I'd really appreciate any help or advice.
    Duke
  2. shawkins002
    shawkins002
    Dec 12, 2002
    237
    Epsom, Surrey
    I spent ages on my PD30 settings with Avia. I could never get quite get the perfect RGB balance, and I must have spent months trying. Lowering the green and reds (which can be way too high) gave a bit of a blue haze - naturally, as there is a balance between the three. It drove me nuts for ages.
    In the end I found that setting the colour balance to "warm" in the normal picture settings, and trying again with Avia did the trick. I haven't touched any settings on my PD30 in probably 6 months now.
    Good luck.
    Simon
