Panasonic PD30 and Xbox
Discussion in 'General TV Discussions Forum' started by jerkyboy, Dec 24, 2003.
Tags:
  1. jerkyboy
    jerkyboy
    I am considering buying a Panny PD30 for use with DVD's and Xbox.
    Is the Xbox picture quality much better using component ??.
    Is it much sharper than a normal RGB scart ??.
    Any problems with this model ????.
    Thanks for any help.
  2. ghost
    ghost
    Hello,
    I recommend you to buy the video pack YUV of Microsoft if you considering buying a PD30.
    The XBOX can output YUV in progressive scan and this television can manage it. However it is necessary to use the XBOX in NTSC to have access to the prossive scan, looks on XBOX forum for more information
    Otherwise the RGB is of better quality than the component but you will need to buy the kit.
    Sorry for my english :rolleyes:
