Panasonic PB50 Service Menu ?
Discussion in 'General TV Discussions Forum' started by Orson, Jul 5, 2002.
Tags:
  1. Orson
    Orson
    Feb 21, 2002
    3,286
    Sunny Ilson, pride of Derbyshire!
    +669
    Does anyone out there know how to access the engineer service menus for a Panasonic PB50, & if so what the functions are?
    I've got the 28" model, which hed.co.uk have agreed to exchange/replace (again :( ) or they will refund. But before I send it back, I wondered if there was anything I could do to tweak the geometry on the main picture, and the difference in picture quality (particularly the colour) on the primary/secondary tuner - after all, I have nothing to lose :devil:
    Any help is appreciated
    Thanks........
  2. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,917
    71
    50 Rue St Georges, Paris.
    +32
    Orson,
    Leave the service menu to the engineers, if you corrupt all the settings your supplier may charge you for remedial work.
    It's better to either have an engineer call to optimise your set, or send it back for replacement unmolested.
    If you are tempted, make a note of all the default settings.:eek:
  3. Orson
    Orson
    Feb 21, 2002
    3,286
    +669
    Yep, I'm tempted, & yep I would of course be extremely careful & note all settings & only change 1 setting at a time etc., but I don't know how to access the service menu(s) to even have a look at to see if there is anything I can change to eliminate the problems I have.
    I would gladly leave it to the engineers, but as yet I have had 3 different engineers, 1 had never had a service call to a TV before, 1 had never seen this model of TV before, and didn't know how to access the user menus (single button press on the remote!) let alone try to rectify any problem, and the 3rd said that almost all new widescreen TV's had geometry problems, and that I was lucky, as most are worse than mine - but he still recommended a replacement! I suppose I have had a combination of bad luck & problems associated with buying from a non-specialist dealer.
    I now have a choice of a full refund, or a replacement (but not another Panasonic PB50 at the request of the dealer), but I found it bad enough deciding on 1 TV, so I am reluctant to go through the whole procedure again, which brings me back to wondering if there was anything in the service menus that may help.
    So, if anyone can help......
  4. Orson
    Orson
    Feb 21, 2002
    3,286
    +669
    I guess not then... Oh Hum, back to choosing a new TV:confused:
