Bargain Panasonic outlet new refurb stock uploaded.
Discussion in 'What Is The Best TV For You?' started by BobTheViewer, Jun 9, 2018.
    1. BobTheViewer
      BobTheViewer
      Oct 16, 2008
      159
      28
      +41
      There have been some decent prices for sets on the outlet recently like 7 x 55EX952 at £999
      some new stock was uploaded and they now have more 50"+ sets available.
      I suspect some of these will go over the weekend.
      link to all
      http://stores.ebay.co.uk/panasonicofficialoutlet/_i.html?_fsub=5800806014
      highlights.
      2 x TX-58DX802B £599 these have been £799 at JL now £899.
      2 x TX-65EZ952B £1,999 these are £2,899 at JL price spy has a low of £2,499
      1 x TX-65EX750B £999 low/no stocks was £1,499 or less
      1 x TX-58EX750B £749 £999 at JL and elsewhere odd code to get it down a bit.
      7 x TX-58EX700B £480 £650 or a bit less at most places
      • Like Like x 1
      • Useful Useful x 1
      • List
    2. Dodgexander
      Dodgexander
      May 29, 2007
      13,692
      +3,963
      And before anyone asks, yes there is more of a risk involved when it comes to having to return the TV if you end up with a fault, however it's worth the reduction if you are prepared to go through the process of arranging a return just in case.
    3. BobTheViewer
      BobTheViewer
      Oct 16, 2008
      159
      28
      +41
      Turns out not all TV stock is on that page there was another 55EZ952 at £999 lurking so I went for that.
      Hope it is a good one.
    4. BobbyMac
      BobbyMac
      Aug 26, 2011
      6,130
      +1,036
      Just quote DSR and make it Panasonic’s issue
      • Agree Agree x 1
      • Useful Useful x 1
      • List
    5. cobaltqube
      cobaltqube
      Jan 26, 2013
      173
      28
      Maidenhead
      +52
      Hi there, how did you find the ez952 Refurb? Did you keep it? Any issues? Did it come in the original box?
      Thanks, ordered the 65ez952 and in two minds... should be arriving next week
    6. BobTheViewer
      BobTheViewer
      Oct 16, 2008
      159
      28
      +41
      came in a pani box looked like the original, still had the foils(film) on the screen, bezel, back and remote. some of the bits were still in sealed bags.
      As far as I can tell the screen is uniform from the testing and any backgrounds on the various players and NowTV, still getting used to the blacks and the dynamic range.
      Not found any reason to send it back
      edit to add
      Took the screen foil/film off on Friday the picture hardly looks any different the reflections are much dimmer. My foil had a few bubbles and two black labels on it near the bottom, without those you could miss there is a cover on the screen.
    7. BobbyBoucher
      BobbyBoucher
      Jun 19, 2018
      7
      4
      Bristol
      Great post. I went from a 55 to a 50 for my recent New TV Quest. Hinsense almost got me until i saw the Panny 50' 700b for £349.
      Well I was not able to have it deliverd on a sat so had to get a refund. Gutted as great deal for £349.
    8. cobaltqube
      cobaltqube
      Jan 26, 2013
      173
      28
      Maidenhead
      +52
      Thanks for that mate, puts me at ease somewhat - mine's arriving on Wednesday. When you say "still getting used to the blacks and the dynamic range.", I take it that's a good thing, right? :)
      How are you finding the motion so far, any stutter observed as yet?
    9. BobTheViewer
      BobTheViewer
      Oct 16, 2008
      159
      28
      +41
      I have seen some motion/blur issues on lower quality stuff but the football and tennis on the BBC UHD streams are OK so far, as are the freeviewHD channels and my NowTV and VM feeds.
      The TV is brighter than the old plasma on everything, sometimes it feels a little too bright like in the world cup studio.
      on programs that have a lot of dark material like from NOWTV "The 100" and "DC's Legends of tomorrow" it feels a little compressed in the dark areas, I think I need to do some tweaks to get that a bit better and extract more detail.
    10. cobaltqube
      cobaltqube
      Jan 26, 2013
      173
      28
      Maidenhead
      +52
      So is the motion something you'll be able to live with, considering you came from a plasma?
      Yeah I think a lot of that noise/compression in near black is also often due to the quality of the source i.e. low bitrate content. Or are you talking about crushed blacks?
      Overall though, would you consider it as superior over your plasma?(motion aside)
    11. BobTheViewer
      BobTheViewer
      Oct 16, 2008
      159
      28
      +41
      benefits(bigger, brighter) access to UHD/HDR content and freeviewHD on board out way any niggles.
      Not touched the controls other than choose pro1 for most sources so far.
      (been busy going out a lot)
      I don't think the blacks are noisy just lacking detail, any part of the scene with a tiny bit of light looks a lot better even if still relatively dark.
      I think I need to plug the plasma back in and have a look at the same source side by side to see if I am missing something or the image really should be that black.
      Beyond the picture the set is so much nicer looking and the smart features are making the interactive experience easier for both of us, would be nice if they got NowTV included.
    12. kharma45
      kharma45
      Oct 31, 2007
      455
      28
      Londonderry/Derry
      +71
      If only they'd deliver to NI, that 50" EX750 would be mine.
    13. Aquila66
      Aquila66
      Jul 8, 2018
      tyneside uk
      Thank you for sharing bagged a 40EX700B
    14. martinthorn1
      martinthorn1
      Mar 6, 2011
      205
      Hampshire, Uk
      +31
      55EZ952 is now at £949.. (picked up one last week for £999 which is slightly annoying but still a lot lower than the original price!)
    15. rs1969
      rs1969
      Apr 26, 2012
      4
      Sorry to dig up an old thread.
      I would be interested to know what are the warranty terms on Panasonic refurbished products. Their eBay outlet states the following:
      Faulty Products – after 14 days of receipt (Excluding cosmetic/accidental damage or customer misuse)
      If your item develops a fault within the 12 Month warranty period we will offer a FOC repair upon receipt of the item at one of our approved service centres. You are responsible (including costs) for transport of your item.
      Please use our service centre locator to find your closest Approved Service Centre: Service Centre Locator
      Is that actually legal? Who would want to buy a refurbished product and then pay for return costs if defective within the warranty period?
      Please share your experience on this.
    16. cobaltqube
      cobaltqube
      Jan 26, 2013
      173
      28
      Maidenhead
      +52
      I can't comment on legality, but yes, I did read and confirm the above conditions as well before I made my purchase from the official Panasonic eBay outlet - in my case, I had 30days grace in which I could return the product for whatever reason, and that was a collection service(If I decided I wanted to return it). Thankfully, I have had zero issues with my 65" EZ952. But yes, to your point, I would dread having an issue and having to send in a 65" TV to a repair center! :0
      You pays your money and you takes your chances!
    17. Dodgexander
      Dodgexander
      May 29, 2007
      13,692
      +3,963
      I returned my 65" DX902 outside of that 30 day period and didn't have to pay for shipping either way, I don't know if I was an exception or not though.
    18. rs1969
      rs1969
      Apr 26, 2012
      4
      Ok that's a return but still there hasn't been any response from buyers who had to get their TV repaired or replaced within the warranty period.
    19. Dodgexander
      Dodgexander
      May 29, 2007
      13,692
      +3,963
      No, I returned my TV for a repair and it was outside the 30 day period..
