Panasonic or Oppo upscaling DVD?
Discussion in 'Blu-ray & DVD Players & Recorders' started by interbear, Apr 24, 2007.
  1. interbear
    interbear
    Mar 22, 2007
    1,177
    +175
    Delighted with my new Panasonic 42PX70 plasma so far, a week of running in and it's superb. I'm looking at a new DVD player to accompany it. However, I'm not sure whether to go for an 1080p upscaling DVD in which case I'd go for either the Oppo 981(£189 via CRT Projectors) or new Panasonic S53 player (around £99 from DABS, MRM etc).
    http://www.panasonic.co.uk/dvd-playe...eb-k/index.htm
    I've seen plenty of good reviews for the Oppo player, has anyone tried the Panasonic?
    Of course I could hang on and wait for the HD-DVD / Blu-Ray format war to end, but that could be a while......
  2. jkirk
    jkirk
    Oct 12, 2005
    154
    +4
    I got the Panny S53 on Monday. Set up was easy and scales to 1010p etc. I got this because I cancelled an order for a Denon 1930 that was taking too long. Saved meself £90 and great pic to boot. Am running it with a panny 37px70. Lurvelly !!!
  3. ozzzy189
    ozzzy189
    Jun 1, 2006
    7,778
    North Lincolnshire
    +1,240
    Was going to recommend the 1080i oppo to a mate, but then i read this---
    'Since the 970HD does not have 2:2 pull down for PAL film, we do not recommend it for PAL playback, other than via a scaler or into a display that accepts interlaced HDMI input (480i / 576i) '
    Anyone shed any light on this ? I was thinking of getting this too. (oppo 970HD) Prob wont need the more expensive 1080p one.
  4. AnthonyG
    AnthonyG
    Nov 23, 2005
    8,855
    +1,188
    I say go for the Oppo. It is a fabulous DVD player, and not just due to its amazing PQ.
    Everything about it says attention to detail with care and thought into making an excellent system.
    Finally one other thing about the PQ, it is not just that it upscales. But it also makes the image seem more vibrant and colourful.
  5. AnthonyG
    AnthonyG
    Nov 23, 2005
    8,855
    +1,188
    I have the Oppo 981HD and it plays both PAL and NTSC DVDs perfect on my UK 32LXD70 Panasonic LCD.
    The 981HD also has a setup menu allowing you to set if your TV is PAL or NTSC.
    I have it set as Auto select and it plays everything perfect.
  6. gctwnl
    gctwnl
    Mar 11, 2007
    59
    A PS3 will play Blu-Ray and DVD, so that is probably what we'll be doing.
    Anyway, we are using a Panasonic S325 (new model probably the S33), which is a rather cheap DVD-player (€80), but which has component out and does progressive scan (576p). This player is connected to our new Panasonic 37PV70F.
    For normal DVD's this produces a very good result. I have been wondering what the use is of buying an expensive upscaling DVD-player if the upscaling done by the Plasma panel itself is already good.
    What did make a *big* difference for the quality of the picture was 576i vs 576p. When still in interlaced mode, the panel had difficulties producing a nice picture, but as soon as this cheap player sent out the progressive signal, the result was stunning (especially considering the price).
    So, if you have a 42PX70, why do you need an upscaling player at all for normal DVD's? After all, letting the DVD-player upscale 576p to 1080p and then the plasma downscale 1080p to 1024x768 must be less preferable than letting the plasma upscale from 576p to 1024x768, depending on how good the various upscalers are of course.
  7. interbear
    interbear
    Mar 22, 2007
    1,177
    +175
    Thanks for everyone's input.
    That's a good point, hadn't thought of that..........:eek:
  8. jerry
    jerry
    Jan 6, 2002
    428
    london
    +18
    JKIRK your the first person I,ve seen on these forums with an S53. I,ve 37px70 as well, can you say a bit more about it. Formats it will play, ease of use with the px70, how much did you pay etc.
  9. yetanotherbob
    yetanotherbob
    Mar 22, 2007
    637
    28
    London
    +55
    I considered the S53 to partner my 42PX70 but opted for the Oppo 981HD purely because of the proven PQ and the fact that it will play everything you can throw at it straight from the box. It cost £189 compared to c.£99 for the S53 but it is a lovely piece of kit :smashin:
    Bob
  10. jkirk
    jkirk
    Oct 12, 2005
    154
    +4
    jerry
    I got it from multiregion magic for £109 incl postage. Arrived after 2 days - great service.
    At the mo, only used it on DVD videos and very pleased with it. For full formats etc see the panny web site. There are some restrictions on some formats but to be honest its a DVD player and most of my use will be with dvd vids only.
    Dead easy to use with the panny - plug it in via HDMI and 2 mins to set up.
