Shuffler1234
I've come across a similar thread recently but it is still confusing to me whether I have compatible signals !
I have a Panasonic TX-50HX820B (2020) LED HDR 4K Ultra HD Smart TV, 50 inch with Freeview Play & Dolby Atmos purchased in 2020.
I would like to connect my 15yr old Panasonic DMR-EH80VEB Video/DVD Recorder so that I can play some old videos.
Would a scart to HDMI cable do the trick, or do I have to connect via video/audio phono-type cables, or are the two not compatible ?
The recorder has an analogue tuner, so I believe I leave the digital roof aerial antenna going into the TV anyway - in the 'old days' this would be routed via the recorder to the TV.
One step at a time - if I can get this to work then I have a younger DVD player (that can play the small discs too) that I want to 'plumb' in as well !
Any help most appreciated ! If it would be simpler and cost effective to get some other video player (don't need record function) and connect that up that would be fine, and dispose of the old one !
