Panasonic NVMX8B or NVEX21B
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by Eff, Jan 3, 2002.
  1. Eff
    Eff
    I've been looking at buying a digital camcoder and the Panasonic NVMX8B and NVEX21B seem to have all that I want but I can't decide on which one to go for.
    The camcorder will mainly be used when I go snowboarding so the smaller NVEX21B would be ideal but with the docking system I wasn't sure if this was prone to problems later on.
    If anyone can offer some guidance or maybe there is another camcorder with a similar specification that you can recommend, I would be grateful.
    Many thanks.
    PS. I'm completely new to camcorders.
