Panasonic NV-GX7 v Sony DCR-PC101?
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by Sands, Jun 18, 2002.
  1. Sands
    Sands
    Hi all,
    I am finally ready to take the plunge and get my first DV cam. These are the two models that I am contemplating with the Panasonic at £800, the Sony at £890. I am also seriously considering the JVC GR-DVX507 at £620. All models have DV in/out, but the Panasonic and Sony are higher spec with Analogue in/out and higher resolution on the stills. The Panasonic I believe has a built-in flash whereas the Sony does not. Basically has anyone got any views or recommendations on these three cams? Is a built-in flash essential? Shall I just go for in this case the budget option of the JVC?
    Any help will be greatly appreciated
