Panasonic NV-GS15 filter installation
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by lopsl, Jul 29, 2005.
  1. lopsl
    lopsl
    Does anyone know how to take off the lens hood of the NV-GS15/GS11 without breaking it ? Can it really be unscrewed ?
    I want to attach a UV or Skylight filter and the user manual says that the lens hood can be taken off by rotating it counter clockwise to attach the filter and then reattaching the lens hood over the filter.
    I have not yet been able to unscrew the lens hood using normal hand strength.
