Panasonic NV-GS120
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by Stuart Mitchell, Feb 20, 2005.
  1. Stuart Mitchell
    Stuart Mitchell
    I have spent a great deal of time with the above Camcorder trying to transfer a full tape on to my pc to edit it in Adobe Elements,I have realised that the Camcorder has USB and Adobe has F/W, Would I be correct in thinking that you are unable to transfer DV images via USB?
    If that is the case do I need a new camcorder or do you have any ideas how to transfer moving images from my camcorder to my pc to edit.
    My OS is windows X/P.
  2. Roy Mallard
    Roy Mallard
    your cam has a firewire connection, try under the flap on the grip side of the body.
    with adobe elements (possibly the best value editing package in the world ever (TM)) connecting your cam & editing is easy
