Panasonic NV-GS11 MiniDV
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by phazer, Jul 13, 2004.
  1. phazer
    phazer
    Anyone got this cam? I can get it at a good price, but apart from the specs given by the salesman I cannot find much about it on the net.
    Anyone know more about it?
    Like what's it's max recording resolution, etc.
  2. w4yne
    w4yne
    May 9, 2004
    40
    Wales
    Full spec here
    I have one and I am very happy , it`s small , light and easy to use and don`t be put off by the price as IMHO it`s just as good if not better than cameras that cost quite a few pounds more .
  3. Leander
    Leander
    Mar 11, 2003
    138
    Ainsdale
    +7
    Phazer,
    just got one and overall very pleased although I've hardly had time to get to know it properly.
    Resolution is showing as 720x576 in my editing software when set for PAL but I've not actually seen this as quoted anywhere.
    Only downside so far has been excessive wind noise on the mic. There is a setting to reduce this but I haven't used it yet to assess its effectiveness. I've only really used the camcorder once and didn't realise how much noise there was until I played it back.
    Hope this helps.
    Cheers,
    Leander
  4. mccrack
    mccrack
    Jul 12, 2004
    27
    Got this cam as well. Very happy with it.
    regards
    ./ronald
  5. phazer
    phazer
    Thanks for all the replies.
    I went and bought the cam, and so far are quite happy with it.
  6. Ish
    Ish
    glad to hear this. i've just ordered this cam as well :)
