Panasonic NV-GS1 - video to pc/dvd
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by johncoca, Oct 23, 2005.
  1. johncoca
    johncoca
    Hi everyone! :hiya:
    Been given a Panasonic NV-GS1 mini DV from the parents with a request for the dv tape to be put onto a pc so it can then be put onto dvd.
    The software i have been given is to capture stills only.
    The video camera itself has got an av out and s-video out but thats about it.
    Desperately in need of some advice/guidance, do i need some hardware/software or is it destined to stay on tape??? :lesson:
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,618
    Rainham Essex
    +2,547
    Nope, getting the footage off a DV tape and onto a PC is very simple. Along with the connections you mentioned the cam will also have a firewire port. This is the only way to get the video onto a PC as it will keep 100% quality of the recording on the tape. If your PC does not have a firewire port you can add one on a PCI card and this should cost you between £10 & £20 and include a cable to connect the cam to it.
    If you are ruinning Windows XP then you have good basic editing software as part of the install called Movie Maker. As long as you are fully up to date with the MS updates then this will be Movie Maker 2. Full help and advice on useing it can be found at www.papajohn.org however it will not create a DVD. To create a DVD you will need to buy other software such as Nero 5.5 or later or Ulead DVD MovieFactory (approx £30).
    If however you don't have XP then as long as you are running Windows 98se or later you can buy some good software for around £40 to do the job, and this should include DVD authoring tools to create the final DVD discs of your footage.
    Good luck with the creation of your blockbuster movie :D
    Mark.
  3. johncoca
    johncoca
    Cheers! Found the firewire connection, got movie maker just need the cable.
    hopefully that movie is on the way :clap:
