panasonic nv-ex3b help
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by yorky22, Mar 1, 2003.
  1. yorky22
    yorky22
    hi all
    could enybody help me out i have the above digital camcorder does enybody know how you transfer it to vcd or dvd thro your computer,i have just orderd dazzle dvc80 will this help me
    regards
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,312
    Rainham Essex
    +2,425
    The Dazzle dvc80 is an analogue capture device and you have a DV (digital) camcorder.
    The dvc80 will work with your camcorder and PC (as long as it is a fast PC with USB ports!), but as you will be capturing in analogue you will be loosing quality.
    You will be better getting a cheap (£50ish) DV capture card and do all your editing in digital. This will give a far better final VCD, or even better, DVD. If your PC is modern it might even have a Dv (firewire/ieee1394) port installed or even the new Soundblaster Audigy cards have a DV port. All you will need then is some editing software and if buying a DVD burner you may find that this comes with all the software required. Otherwise there are loads of fairly cheap but good products such as Pinnacle Studio 8.
    Mark.
