Panasonic NV-DS60
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by kev269, Jun 12, 2003.
  1. kev269
    kev269
    I understand that the Panasonic NV-DS60 is a Mini-DV.
    What I want to know:
    What does the video record on to, do i have to buy Mini DV tapes to put in the camcorder? or does it have built in memory?
    If it is on tape, how long would i be able to record onto one tape?
    Is the only way to connect the camcorder to the computer by Firewire? or can i use USB ?
    Kev
  2. gunsj
    gunsj
    Q1: yes, yes, no.
    Q2: usually 60 minutes, 90 in lp mode.
    Q3: see Q2.
    Q4: yes, no usb.
    This is a great value-for-money, affordable cam. High picture and build quality. Has limited optical zoom, no memory card slot, no dv-in port, limited light sensitivity, but otherwise outperforms almost all others at this price. In other words; great for those holiday and party shots. And its quite small, too.
  3. gazthejambo
    gazthejambo
    May 27, 2006
    30
    with nv-ds60
    stand by flashing then switching off
    can any one help
