Panasonic LX500 same as LXD500?
Discussion in 'Panasonic TVs Forum' started by astonbilla, Nov 2, 2005.
  1. astonbilla
    astonbilla
    Feb 19, 2002
    1,484
    +39
    found an LX500 online for a steal - just under £1300 - is this the same as the LXD500 or a European variant?
    any help would be great guys
    komplett.co.uk by the way
  2. Deleted member 92943
    Can't seem to find the LX500 except for on that site. I think it might be a discontinued set.
    The D500 is a superb set which i am buying in the next week or so. Has everthing you can want. HD-MI, Component, 3x Scart, PC Input, PC card Slot, SD Card slot, High Definition and much more
  3. san_marco
    san_marco
    Jun 9, 2005
    32
    Can't see much difference but i would say it doesn't mention that it has freeview. So the D might meen that, but i am not certain
  4. Deleted member 92943
  5. astonbilla
    astonbilla
    Feb 19, 2002
    1,484
    +39
    Lee you definately getting the D then? i keep looking at the price of the sammy le32r41 and the new tosh wlt58 and the difference worries me. I'll have to have another look.
    i only really want xbox 360, dvds and pc connectivity so maybe the sammy would do me. Very little on these pages from users of the LD that have connected a pc which worries me
  6. san_marco
    san_marco
    Jun 9, 2005
    32
    I'm torn between the panny 32 lxd500 with digital direct at £1406.96, or the panny32 lxd52 I have been trying to get a PM with JL but there not having it otherwise an internet company at about £1080 or tosh wlt58 if i can get a PM with JL at £1079. But wont be getting HD for at leat a 9 months as have 9 months to go on exsiting contract with sky. So i will be watching sky on it the most. I have had a look at the 500 and it was good but have not seen sky on the tosh or the 52. I just don't know.
