Panasonic LCD TV Black frame turning blue
denhamcs
I recently bought a Panasonic Viera 32” LCD TV and after about 5 days use I noticed that part of the black frame (bottom - centre) had turned blue. It almost looks like the colour has ‘leaked' from the screen down. The general picture has not been affected and the TV works alright (although you do have to hold the on button on the remote down for a few seconds before the TV will come on).
Any advice? I am not sure whether to take it back to the shop or not.
Mod Edit: font tags removed
redaprilia
Yes that's quite correct , certain models that have a semi translucent frame have a blue hint to the frame when viewed in bright light . Its not faulty .
Podcast: Trinnov Room Optimiser: A full explanation of Trinnov and its room optimiser technology
