I’ve just got a couple of Zidoo’s also, better PQ than Shield, but kept my Apple TV boxes for streaming..
ATV 4K doesn't need to be connected to a HDMI 2.1 port. eARC sound bar does need to connect to a HDMI 2.1 port as one of the two 2.1 ports has the single eARC connection.Hi Everyone,
I hope you can help - I am really interested in the JZ1500 model.
I am not sure about the available connections. I have an Apple TV 4k 2021, Xbox Series X and planning to purchase a good eARC soundbar. Will I be able to use these devices with the TV at their best? I know I can connect the xbox and apple tv to the two 2.1 hdmis but what about a soundbar?
Thank you - much appreciated.ATV 4K doesn't need to be connected to a HDMI 2.1 port. eARC sound bar does need to connect to a HDMI 2.1 port as one of the two 2.1 ports has the single eARC connection.
I did away with my Nvidia shield and went with a Zidoo Z9X. Prefer how it handles Dolby vision and just seems to pop more than the shield did. As the TV apps are super responsive and the upscaling is good, I also didn't need the streaming side from the shield anymore and the Zidoo was better option for playing my rips.
If they are like the Dune players they can run Aptoid but these aren’t great for running apps. You are better off using the TV’s internal apps.Looked up the Zidoo Z9X you mentioned and the consensus seem to be that it is a much better player than the shield for HDR content all around.
Very interested in this player now.
Have they implemented the google play store in its OS or do you still have to sideload the APK's for the apps?
The problem you have is that you haven't seen it before 3 months have passed. You should be contacting your retailer rather than Panasonic although they may just say the cause is accidental damage by yourself. How big is the chip and where is it?Does anyone have any experience with panasonic customer service? I have had my JZ1500 for under three months with very little use. Today while dusting the TV i noticed a small chip in the panel. Now i have noticed it and in light of the fact its a £2500 panel i would really like to have it repaired or replaced. Would this be feasible?
If anyone's interested I did this earlier. Seems to work. I used an old USB stick and just the black pattern from the link in the first post here.Has anyone tried using the "Scenery" mode as a screensaver?
Am I right in thinking a full 100% black slide will basically turn the screen off on an OLED?
I was thinking about adding a black slide to the scenery app as it has a dedicated button. Then it's like a one press screen saver for when content is paused.
Is everything grainy, or just certain material?Hello - new JZ1500 owner. I’m currently loving my new TV! I’ve been lurking for a while; if anyone else is in the same boat, don’t think twice! I have a 65” and sit around 6 feet away - I’m sooo glad I didn’t go for the 55”!
I have been using scenery as a screen saver, but with the actual scenery (minus the static date and time - this seems counter intuitive?!?). It’s actually really relaxing!
Potential noob question: when I watch in Dolby vision (4K disk, Disney plus) the image seems quite grainy; this can’t be correct, surely? I’m using the AV Forums‘ video suggestion of Dolby Vision Dark, with nothing else turned on. I’m sure I’m missing something, and would appreciate some help!
I use Dolby Vision IQ or Dolby Vision Dark. I find Vivid is just too garish and changes the colours quite drastically. If the picture is too dark on the non-Vivid presets you can adjust brightness and gamma till you're happy with the picture. I find the default gamma too dark for my liking.Do you people watch netflix with the netflix calibrated mode on or off? (for Dolby Vision content)
I find that i need to turn it off during the day so i can manually switch it to Dolby Vivid Settings for more brightness. As i have ambient light reflecting from the tv in the netflix calibrated mode.
It’s only on Dolby Vision, and only on Disney plus (either TV app or Apple TV app). It looks like a 720 source in dark scenes. A 4K disk in Dolby vision looks great. I’m using Dolby vision dark with everything off processing wise. I’ve tried adding some processing but the image looks the same (or worse). Netflix / Amazon look great, so I don’t think it’s a WiFi issue (I’m using a Netgear hub, so it’s not a store freebie). I’m really looking forward to watching loads of Marvel shows, and would love to improve the dark pictures.Is everything grainy, or just certain material?
What is the picture like for Disney+ if you turn off Dolby Vision?It’s only on Dolby Vision, and only on Disney plus (either TV app or Apple TV app). It looks like a 720 source in dark scenes. A 4K disk in Dolby vision looks great. I’m using Dolby vision dark with everything off processing wise. I’ve tried adding some processing but the image looks the same (or worse). Netflix / Amazon look great, so I don’t think it’s a WiFi issue (I’m using a Netgear hub, so it’s not a store freebie). I’m really looking forward to watching loads of Marvel shows, and would love to improve the dark pictures.
Any advice is more than welcome!
Sorry, no idea - I haven’t tried it. I’ll give that a go when I can.What is the picture like for Disney+ if you turn off Dolby Vision?
Since it's only Disney material then it might be an app issue. From what I've seen, app behaviour on the JZ series is not consistent from user to user. For instance, I don't get Atmos on the Amazon Prime app but others do. My Apple TV app wouldn't even start until I did a factory reset and tried again. And even after the restart I don't get Dolby Vision from Apple TV (but I get it from the other apps) and it streams in the wrong aspect ratio too.It’s only on Dolby Vision, and only on Disney plus (either TV app or Apple TV app). It looks like a 720 source in dark scenes. A 4K disk in Dolby vision looks great. I’m using Dolby vision dark with everything off processing wise. I’ve tried adding some processing but the image looks the same (or worse). Netflix / Amazon look great, so I don’t think it’s a WiFi issue (I’m using a Netgear hub, so it’s not a store freebie). I’m really looking forward to watching loads of Marvel shows, and would love to improve the dark pictures.
Ah that explains it. But for some reason everything is stretched to fill the screen when I watch Apple TV. I can't see any way to change the aspect ratio. In general I'm very frustrated with Panasonic's smart interface, even though I went in knowing it was a poor show compared to the likes of LG and Samsung. They really should have licensed Google TV like Sony has done. Although Netflix, iPlayer, and Disney are working properly, my issues with Amazon and Apple TV have really soured things. So for now, my Shield is here to stay.Don't think DV is available yet on Apple TV on the TV app just for reference. Hopefully will come on a further update.
