Kiwi Paul
Greetings, I have a new Panasonic TH-55JZ1000Z TV and a new Panasonic SC-HTB600 home theater system both purchased in April.
I am having trouble with the sound cutting out intermittently when through the soundbar.
The sound cuts out but the soundbar still shows ’TV’ on the display.
No fault codes show up.
After a time, from seconds to minutes the sound returns and the display rolls through like it is just starting up.
Sometimes it is necessary to turn the soundbar on and off to get the sound back.
The sound is constant when it goes off, not quiet or loud.
Some days it happens several times, than it may not happen the next day and I think it is okay but next day it is back again.
The soundbar serial number is: TS1EB001391
Update version: M1.49
Soundbar connected by HDMI 2.1 cable to eARC slot
Sounbar settings to no Auto Off
TV settings to PCM, eARC on
I have swapped HDMI cables but no difference.
The soundbar sits in front of the TV and is not hot.
We do not use the subwoofer so that is not affecting it.
A reset made no difference.
I have a Phonak TV Connector for my hearing aids which is connected to the TV with an optical cable which means I am getting sound from the TV directly and my sound does not go off when the soundbar sound does which suggests the problem is with the soundbar.
I have a support ticket in with Panasonic but am posting here in the hope someone else may have had the same issue and found a solution.
Any suggestions would be appreciated, kind regards, Paul R
