Panasonic HS2
Discussion in 'Blu-ray & DVD Players & Recorders' started by Phil.LFC, Jan 2, 2004.
  1. Phil.LFC
    Phil.LFC
    Mar 31, 2002
    729
    Staffordshire
    +57
    Sorry if I sound a bit excited but I've had a couple of beers and I'm totally blown away by my new HS2:clap:
    This is one fine piece of Home Entertainment kit. I've only had it for a couple of days but I've already copied from Sky+ (also superb:D ) to the HDD and then edited and then copied to DVD-R with no problems at all, despite a dodgy manual:eek:
    I even managed to play the finalised DVD-R on an old Toshiba SD100 DVD player.
    Sky+ and the HS2 are an AWESOME combination. If you are considering either, just (to quote from Tom Cruise in Risky Buisiness) say "once in a while you've gotta say what the F***)
    DO IT!!!!!
  2. TraceyJ
    TraceyJ
    Dec 11, 2003
    83
    I love my new HS2/Sky+ set up too :clap:
    what brand dvd-r's are you using Phil?
  3. Ged
    Ged
    Apr 29, 2002
    925
    +17
    Isn't it it just the D'S B'S!
    Tracey, I have used white label discs at 90p, work well, from the local comp fare(Bowlers).
    Our local Morrisons is selling Maxell 10 for £15 including cases.
    I think they have a generous returns policy!
    Never had a duff disc apart from messing on the pc.
    Ged
  4. Phil.LFC
    Phil.LFC
    Mar 31, 2002
    729
    Staffordshire
    +57
    Just to start me off I bought a 5 pack of Maxell's for £10 from ASDA whilst shopping! Only used 1 so far but no problems at all. Isn't it nice to buy something and have it work faultlessly:smashin:
    Looks like Morrisons might be a better bet though!
  5. Ged
    Ged
    Apr 29, 2002
    925
    +17
    Phil,
    It is one of their buy one, get some deals.
    One day they will implode on the deal, I have bought Imation CD-R's, 10 for £6 or 30 for £10, maybe one day it will be all you can carry and here's a Fiver!
    Ged
  6. phelings
    phelings
    Jul 24, 2003
    1,025
    36
    If you use mail order you can get quality dvdr from JVC,TDK,Sony etc for about £1.30 ish.Stay away from budget discs-Panasonics only downfall.
    Welcome to the club ladies and gents.You are now fully fledged members of the high quality HDD/DVD brigade.
    DVD+?:suicide:
  7. TraceyJ
    TraceyJ
    Dec 11, 2003
    83
    Thanks everyone - I've just ordered a batch of panasonic ones from 7dayshop, oh and a trial pack from somewhere else which has already arrived - I've used the 'Datasafe Media' dvd from there which was fine :)
  8. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    leeds UK
    +14
    No problem with datawrite yellows and greys at under £1 a time, no need to buy the expensive branded media, also traxdata and others have been fine, just avoid bulkpak.
  9. TraceyJ
    TraceyJ
    Dec 11, 2003
    83
    is datawrite the same company as datasafe then? the one I used had a purpley dye - read a lot about dyes on here - still not really sure what I should be looking for!
  10. phelings
    phelings
    Jul 24, 2003
    1,025
    36
    If you worry about 30 or 40 pence a disc,shop around on the web.But as you can see there are ifs and buts about most brands of the budget type.If you stick to the top brands you should be ok.Who wants to worry about whether such and such dye is ok-this forum is full of threads about Panny machines having trouble with budget discs.But its a chance you take
  11. Phil.LFC
    Phil.LFC
    Mar 31, 2002
    729
    Staffordshire
    +57
    Followed Ged's advice and went to Morrisons.
    £9.99 for 5 Maxell DVD-R's or 2 packs for £14.99, that's only £1.50 each, and they come in proper full size DVD cases:clap:
  12. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    31,763
    Bristol
    +6,367
    What is classed as a budget disc because when it comes to dvd writers you cant do much better than RITEK but it seems on dvd recorders they are not so good and that cheaper discs work better, very confusing.
  13. mikescollan
    mikescollan
    Been using BigPockets Professional Budget 4x £14.95 for 25.
    Initially bought 25 to see how they went. Used all 25 without problems. Bought 100 more and have used about 20 with only one Finalize error. The disk that errored still plays OK (but only on the HS2). This works out at 45 disks used one failure or 60.3p per disk.
    Will feedback further when I have used up the batch of 100, but would imagine I'll be getting more.
