Panasonic HS2
Discussion in 'Blu-ray & DVD Players & Recorders' started by ricko, Dec 10, 2003.
  1. ricko
    ricko
    Dec 10, 2003
    11
    A bit of advice please from the experts!
    I'm looking at buying the HS2 - but understand it doesn't play CD's or MP3.
    1. Is this right?
    2. If I buy it is there a mod?
    3. Any other options for MP3
    The system I am thinking of buying is:
    Panasonic HS2
    Pan 32PS5 (TV)
    Goodmans GDB3 (digi reciever)
    I already have a Pioneer A-300 Amp (old but good) and a Marantz CD-52 MkII CD player and was hoping to incorporate these into my system.
    Cheers in hope of any advice
    Rich
  2. yonderblue
    yonderblue
    Dec 18, 2001
    302
    Scotland
    +12
    1. The HS2 will play Audio CD's (and CD-R/RW's) only the newer E50/E60/E100 will play MP3's written to a CD-R/RW (Not sure about DVD-R's, Probably not).
    2. No, Not unless you go for a E50/60/100
    3. see 2 :) or buy a cheapo £30-40 DVD player from Sainburys, Safeways, Tesco etc that will play anything including MP3's to go with a HS2.
  3. bobones
    bobones
    Jan 15, 2002
    453
    +7
    Make sure you get a freeview box with 2 scarts and preferrably one with s-video on the vcr scart. Pioneer box from Richer Sounds at £80 looks good.
    A very cheap (but less flexible) alternative to the HS2 would be the Humax PVR (40GB single tuner freeview recorder) and an E50 for about £420. Or a Pace Twin (20GB) and E50 for about £460.
    You can connect the HS2/E50 to your A300 for listening to stereo and use your Pan tv for 5.1. A better, but more expensive, option would be to get an a/v amp/receiver with preouts, then you can use your A300 for driving the fronts in 5.1 and stereo. Something like the Yamaha 640 would do the job.
  4. ricko
    ricko
    Dec 10, 2003
    11
    Cheers Yonder & bobones - I've got a couple of more options to research - I apreciate your responses
    Rich
